-   -   1988 Maxima serpentine belt (https://nissanforum.com/forum/nissan-maxima-12/1988-maxima-serpentine-belt-2689/)
Zilla830 Oct 24, 2006 04:02 PM
do i really have to take EVERYTHING apart just to change this freakin belt?
reiska Oct 25, 2006 04:27 AM
RE: 1988 Maxima serpentine belt
if u dont, then engine will do it... piston rings may stay on place:(
Zilla830 Oct 25, 2006 02:06 PM
theres no easier way?
reiska Oct 26, 2006 04:52 AM
Lots ppl think that just drivin is the easy way out. uh.
The belt is warranted 60k/5yrs. This is general, and has wide errormargin. Some tell they drive 15yrs before engine is destroyed, who knows how far one can get? I drive very little, cold/north, so I plan to stretch 'my 5yrs' but I wont recommend this to anyone: I have tightened the belt one yr later as I have added a service hole for it into the cover. The slack from stretching is the main reason why belt jumps/snaps.
The VGE as most engines have a spring loadded roller. No source (!?) tells this, but releasing the roller lock hex nut, releases the spring which causes beautifull exact tension on the belt. The service is: Just loosen, tighten. Maybe this is too cheap $ervice...
Open top screws, bend/pry cover ajar, test how much loose slack there is. 20lb downward force should bend half inch... now you may know how fast belt needs action.
