-   -   1995 maxima problem (https://nissanforum.com/forum/nissan-maxima-12/1995-maxima-problem-3893/)
maxima1995 Jul 4, 2007 06:37 PM
1995 maxima problem
Ihave a 95 Maxima. I'm having trouble starting it. It seems to be the security system thats not allowing the car to start. My battery is good, cause all other power works just fine. SometimesI have to jiggle the steering wheel. Other timesI have to jiggle the gear shift. But mostly nothing works, andI just turn the key, all lights are on, but it doesnt start. Its not turning over. Any suggestions?
Patty_ost Jul 21, 2007 01:59 AM
RE: 1995 maxima problem
maybe its from the immobilizer of your security system
reiska Jul 21, 2007 07:15 AM
- Steering wheel is mechanically connected to ign sw, possibly worn. Replace (worn sw is a potential fire hazard)
- Gear selector inhibit switch and/or its wiring may also have contact problems, check/correct. This and security system controls also inhibit relay which may be stuck intermittently. To troublershoot, swap places with it by some other relay (same color)
- starter soleneoid, its wiring may also be worn out...
- check this page5 & page10 &14 http://www.cardomain.com/ride/748507/5
powerband Jul 21, 2007 08:33 AM
u need to check ur neutral switch may b its not going in park properly sometimes d shifter cable bushing is worn n it doesn't put it in park r other gears correctly if it automatic trans check to c if ur starter solenoid is good,starter relay,start wire to d solenoid ,proper ground.if it as manual trans check clutch start switch,key switchwith other things above
[/align]
HXC_Nismo Jul 21, 2007 09:34 AM
check the most obvious first before checking all your switches. take a wrench or hammer anything and tap on the starter case a few good times and if it starts after this then your starter is bad. if it still doesnt turn over then test the starter to see if it spins when you use a jumper from the battery voltage to the s-terminal on the starter solenoid and if it does turn over then start looking at your ign switch and neutral saftey switch
