1996 maxima idle bounce
Old Oct 20, 2009 | 05:16 PM
biznipian's Avatar
Default 1996 maxima idle bounce
i had a more or less undrivable car. i replaced the mass air flow sensor the knock sensor and cleaned the throttle body. i still had a bit of idle bounce or surge from time to time and a hard start a few times a week with some minor drivabiltiy issues. i put some marvel mystery oil in the gas and it got much much better with all issues gone except for a bit of idle bounce or surge from time to time not often any thoughts thanks
Old Nov 3, 2009 | 02:06 AM
Skyler's Avatar
Default i hope this helps
it sounds like u r not geting spark or ur plugs arent gaped right. u also may not have the right plugs in it u wont to use oem or ngk plugs i think urs would be platnum. and u also may have a quoil going out. that should help with the start problem. the other thing u could try if u havent is swich out ur fuel filter. the last thing i can think of is cleen and check that ur battry is charged.it should be around 12.9v if it is fully charged.
biznipian
Dec 16, 2009 11:59 AM
erbimhi
Nov 14, 2005 08:31 PM
erbimhi
Nov 13, 2005 07:37 AM
erbimhi
Nov 13, 2005 07:36 AM
320i
Oct 19, 2005 01:14 AM
