-   -   1999 maxima bose radio (https://nissanforum.com/forum/nissan-maxima-12/1999-maxima-bose-radio-4570/)
JonCam1238 Dec 30, 2007 02:09 PM
My Bose CD player works, but it will not light up. So i am not able to see what radio station I am listening to...SOMETIMES the lights will come back but they will fade out shortly. Any idea's on what it maybe or what I should do? Ive checked all the fuses...
maximaa32 Dec 30, 2007 03:02 PM
RE: 1999 maxima bose radio
which lights are not ON display or illumination lights ?
how about other lights on dash i mean climate/ac control etc
JonCam1238 Dec 30, 2007 03:05 PM
alll other lights on the dash, cluster etc. are on. the seek, #'s(1,2,3,4,5,6) display where it would show the track..cd play time, or radio staion doesn't light up.
maximaa32 Dec 30, 2007 03:14 PM
as per me there is no electrical wiring problem its internal to Cdplayer. you might need a replacement. or have some electronics repair shop to fix it , or if you can disassemble the cdplayer and check the faceplate connector.there will be two connectors check for any burnout or loose/bent connector
let me know ifyou need any help to disassemble
thanks
maximaa32 Dec 30, 2007 03:17 PM
how about a quick check, try to press the faceplate with your thumbs, one thumb near volume control and other near equilizer control and see if display lightsup
JonCam1238 Dec 30, 2007 04:09 PM
actually...i lied. sorry ahah. everything on the CD player does work. it's only the display where the radio staion or track # appears...and i tried pushing onn it and nothing happened
maximaa32 Dec 30, 2007 04:50 PM
then you may need to change the connectors or display ,
JonCam1238 Dec 30, 2007 05:33 PM
alrite. thanks a lot.
