91 max leaks oil
My maxima leaks oil some where right above the power steering pump on the back side of the motor (runs down timing chain cover). replaced cam and crank seals/ cover rtved; also repleaced valve cover gasket. Where the hell is it leaking oil from? cant be head gasket no loss of power or smoke 170,000mi
RE: 91 max leaks oil
Is it really engine oil?
Pry open timing cover upper edge after losing some screws, peek in. Maybe head gasket? (Cant com from hell, all oil has already burned there, fire goin strong forever...) |
| All times are GMT -5. The time now is 09:01 AM. |
