91 Nissan Maxima Rad Fans?
I was just wondering if i have a problem or not. My fans only come on when i turn on my AC or Heat. Is this normal with this model? or should they come on at a certain temp?
RE: 91 Nissan Maxima Rad Fans?
.... fans only come on when ... If so, maybe belt slack, air in system (bleed), pump blades corroded, rad blocked On moderate weather and no A/C on, the fans will not normally start, maybe on long idle. Fans do have 2 speeds. Check out http://www.cardomain.com/ride/748507/7 & page 8 Test disconnect EGRC temp sensor connector: idle rpm raises, both fans at max speed. Now u know that ECU got the signal, energized all 3 fan relays, fans do their job... http://memimage.cardomain.net/member...748507_230.jpg |
| All times are GMT -5. The time now is 02:25 AM. |
