95" Needs Help
Old Jul 27, 2007 | 02:07 PM
BsMax's Avatar
Default 95" Needs Help
I have a 95 GXE and when I turn it on during the idle it makes a loud knocking sound and im sure its coming from the crank casebutwhenI took a look tha pistons where fine.......WHAT IS IT!
Old Jul 28, 2007 | 02:07 AM
reiska's Avatar
Default RE: 95" Needs Help
Rod bearing free play makes nasty noise. Faulty crankshaft or its bearing(s) can also be heard a mile, idle may be ok (happens after stupido ignition adjustment - too advanced ).
Hope your case isnt like mine was...
Old Jul 28, 2007 | 05:14 PM
i would not drive the car like this, make sure you have oil and if you can drop the oil pan and see if there is any chunks of metal in the pan. but i recommend pulling that motor apart and rebuild it or get a used engine cause knocking is not good. good luck
Old Jul 30, 2007 | 12:35 PM
BsMax's Avatar
Thats the second time i got Rod Bearings so THANKSfellas for both ideas ill check my oil pan and open back up tha motor and check it out
blitz
Sep 30, 2006 12:37 PM
mjsdfd
Jul 20, 2006 09:11 AM
eternalee
Jun 20, 2006 01:07 AM
ferdieboy
Apr 28, 2006 08:50 PM
ferdieboy
Apr 28, 2006 08:46 AM
