95 Window Motor Problems
If motor &sw is ok, it may be any problem cut/shor/ting the ctrl data lines to the door satellite; moisture, connector oxidation. Typically first affects the door with longest wiring... Check http://www.cardomain.com/ride/748507/13
it would be much better if you could provide a pic of your jeep window motor.you know it would be easier to point out the solution if you would be able to provide us.
to check the switch hook up a voltmeter to the p/w motor plug and move the switch up and down and see if you get battery voltage, to check the motor use a jumper wire from a 12v source and supply power to the motor and see if it works. if its a cable styl regulator you can useally see it and hear it binding. also it doesnt hurt to check your fuses.
turksteelman
Oct 22, 2007 02:06 AM
