-   -   95 Window Motor Problems (https://nissanforum.com/forum/nissan-maxima-12/95-window-motor-problems-3326/)
95Driver Mar 5, 2007 02:21 PM
I'm not sure if I have had the regulator or the motor go out on the Drivers Side Power window. How can I telland how do you replace either part?
Burnnout Mar 6, 2007 10:34 AM
RE: 95 Window Motor Problems
Hook power directly to motor... if motor works then it's not the motor, it's the switch. Regulator would be visually broken.
reiska Mar 8, 2007 04:19 AM
If motor &sw is ok, it may be any problem cut/shor/ting the ctrl data lines to the door satellite; moisture, connector oxidation. Typically first affects the door with longest wiring... Check http://www.cardomain.com/ride/748507/13
raymundojr Mar 23, 2007 11:32 PM
it would be much better if you could provide a pic of your jeep window motor.you know it would be easier to point out the solution if you would be able to provide us.
HXC_Nismo Mar 27, 2007 01:26 PM
to check the switch hook up a voltmeter to the p/w motor plug and move the switch up and down and see if you get battery voltage, to check the motor use a jumper wire from a 12v source and supply power to the motor and see if it works. if its a cable styl regulator you can useally see it and hear it binding. also it doesnt hurt to check your fuses.
