96 Maxima wont start
Hello guys! I'd appreciate some advice from anyone. I just got me a used 96 maxima.... always wanted one. I had the transmission replaced (5 speed manual), and after then, the car will not start. At first it showed the crank position sensor code. replaced thatm but the car still wont start... Now it shows the MAF sensor code. I've not been able to drive for like a month now.... which really sucks. Does any one know what my problem might be?
Thanks...
Thanks...
...Does any one know what my problem might be?...
He needs air, spark, gas - on time. Which one is miss ing?
- any repairs etc leaving intake seals ripped?
- take spare spark plug, ground it on 'engine bolt', insert into coilpack, crank & peek. How is it?
- rotate by hand the mentioned sensor, while ign on, hear injectors click? Gas smell?
If it worked before tranny swap, quite probably electronical problem. Inhibit relay etc... some wire loose. All troubleshootin starts from voltage checks, at batt, at ECU.
4gen is partly equal to this 3gen, check out: http://www.cardomain.com/ride/748507/5
