-   -   air intake issue (https://nissanforum.com/forum/nissan-maxima-12/air-intake-issue-501/)
nice1a Aug 24, 2005 10:24 AM
air intake issue
i installed an air intake 2 weeks ago - about 2-3 days later the service light came on - when i let off of the gas a stops the idle goes down to 400-500 rpm instead of the 800 it was before. any ideas?? runs a lot better though
Patrick Aug 24, 2005 01:21 PM
RE: air intake issue
i had a similar issue...make sure that you have a snug fit, and that no air is "slipping in" anywhere along the intake. i had a point where the intake was allowing unmetered air to enter, and it was causing the SAME problem.
Maxpl74 Aug 27, 2005 02:04 AM
Sounds like your maf went bad[sm=smiley21.gif] ,a common problem on the 5th gen especially with intakes
vrsexxin Aug 30, 2005 02:43 AM
did you make sure you plug in the maf sensor back, or i hope you didnt drop your maf sensor??? sometimes the ecu doesnt learn right away with more air going in....so i guess if the check engine light does not goes away, try resetting ecu......good luck
RedfoxXx Nov 10, 2005 10:20 PM
did the ecu list any error codes?
