Car is building up pressure?
Hi all, I have a 91 Nissan Max and the radiator system is building up pressure and the car is over heating.. Any tips on what it is? I change the radiator, thermal stat, and hoses.. Can water pump make the system build up pressure?
RE: Car is building up pressure?
...Can water pump make the system build up pressure? Pressure builds also if head gasket blown, I wouldnt suspect that in the first place. |
Quick question... Is the power steering belt connected to my water pump..? It seems like ever since I took off my p/s belt it was over heating..
ORIGINAL: focusonmoney Quick question... Is the power steering belt connected to my water pump..? It seems like ever since I took off my p/s belt it was over heating.. http://memimage.cardomain.net/member...748507_400.jpg [A.] Cranckshaft pulley for 3 belts (Note smaller Pwr steering pulley diameter). [B.] Power Steering pump; b. tightening pulley and [C.] Water Pump employ belt (1.) nearest to engine. [D.] Alternator (used to tighten the belt no.2, Gates Micro-V 48347). [E.] A/C Compressor; e. tightening pulley (for outmost belt 3., Gates Micro-V 48380) |
Note: its known that some pump blades may corrode totally and pump has to be replaced. You dont know before taking it out... Symptoms partially fit your case. But if cooling after bleeding is ok, dont worry about this.
Thanks for the help.. I put the belt on and its still building up pressure in the hose.. Before I replace the pump how do I bleed this system correctly? Do i take off the raditor cap and let it run?? Thanks..
.... Before I replace the pump how do I bleed this system correctly? Do i take off the raditor cap and let it run?? Thanks.. If I remember right, FSM tells to raise the car front 10" while BV is open, check how it is ... top left 'Favorite Links', via link below. |
