-   -   car won't start facing up hill (https://nissanforum.com/forum/nissan-maxima-12/car-wont-start-facing-up-hill-2480/)
maxima97 Sep 22, 2006 01:22 PM
1st post any help would be appreciated. I have a 97 maxima se that won't start if it is facin up hill, no problems starting when facing down hill. I tried replacing the ignition switch but still had the problem. So I put the old switch back in. Then I tried replaced the inhibitor switch and I am still having the problem. Sometimes when I am on level ground it will not start either unless I push the car forward when it is in park and turn the key. I had a mechanic look at it and he was the one that replaced the inhibitor switch. He is not sure what the problem is so I am looking for some additional help. When I mean won't start the starter does not turnover. PLEASE HELP!!!
KA20DET Oct 4, 2006 04:19 PM
RE: car won't start facing up hill
fill up the gas tank
reiska Oct 5, 2006 03:08 AM
When u push, engine which is on rubber bushings, moves. This affects all wires & connectors between chassis/engine.
I suggest you clean and/or swap positive batt-solenoid & solenoid ctrl And gnd wire/terminals. If that doesnt hlp, its starter/solenoid service time.
...gnd wire typically rots away. Take batt tray out first:
http://www.cardomain.com/ride/748507/10 & http://www.cardomain.com/ride/748507/5
http://memimage.cardomain.net/member...748507_463.jpg
