CHECK ENGINE CODES PO440 AND PO446
Old 06-15-2006, 11:13 AM
pnamarble's Avatar
Default CHECK ENGINE CODES PO440 AND PO446
KEEP GETTING THESE CODES WHAT IS CAUSING THIS NEED SOME ADVICE
Old 06-16-2006, 05:42 AM
Default RE: CHECK ENGINE CODES PO440 AND PO446
- smbdy glued kb caps lock on?
- what kinda boat u have?
- if maxima, points to EVAP, find wassup via clicking top left 'Favorite Links', ...see link below
Old 08-03-2018, 05:31 AM
diYdon2018's Avatar
P0440 = Evaporative emission control system small leak, negative pressure.
P0446 = Evaporative emission system vent control valve circuit.
Above is as per Haynes Manual for 2000 & 2001 Nissan Maximas. I've never had to deal with these codes so can't help you further. I hope this helps somewhat to narrow down the possible problem(s).
thebigcheeser
10-26-2007 02:51 AM
buzzuka
10-11-2007 08:30 AM
cbeaur
08-27-2007 06:36 PM
cbeaur
12
07-21-2007 02:31 PM
Nybill44
10-29-2005 06:19 AM
Quick Reply: CHECK ENGINE CODES PO440 AND PO446
