Clearing check engine light
Old Jul 28, 2005 | 12:36 PM
Pod97654's Avatar
Default Clearing check engine light
i was wondering? i have a 99 Maxima and i just a code (check engine light came on) I know that most of the older fuel injected cars could clear the computer by pulling the neg. bat. for about half and hour, does this still work or will have i to get the code cleared by my mechanic?
Old Jul 28, 2005 | 07:44 PM
Pod97654's Avatar
Default RE: Clearing check engine light
I found out that disconecting the bat does not work. but for any one interested i found a free and easy way to check codes and clear codes on 95-99 maxima's.
Old Aug 1, 2005 | 04:54 PM
Jedi007's Avatar
Go to O'Reily or AutoZone and borrow their ODBII Reader. You would probably need to give them your credit card as the collateral. Refer to the manual, obtain the trouble code and clear the "Service Engine Soon" light when you deem appropriate. I reset my 1997 Maxima several time at O'Reily. I hope it helps.
Old Aug 30, 2005 | 02:50 AM
vrsexxin's Avatar
well most of the times when you unplug the negative battery for resetting ecu, it works for minor ecu complications but if anything major like bad maf sensor, o2 sensor etc, it will not disappear by unplugging ecu....my best advice is go to schucks or autozone...but my 2 guess would be maf sensor or misfires..
Old Aug 30, 2005 | 03:18 PM
Patrick's Avatar
Administrator
i would also suggest getting it scanned and find out why its on.
Old Sep 6, 2005 | 05:59 PM
bonbon's Avatar
I need some help, I have a 93 quest. my engine light came on , found the code 33, replaced o2 sensor, cleared code, and worked for few minutes, then came on again with same code, don't know what to do?
mitch84
Nov 21, 2005 11:13 PM
Dragonlord8096
Sep 10, 2005 01:14 AM
sasser43
Sep 4, 2005 04:39 PM
salsarev
Aug 11, 2005 09:07 PM
sideways240sexy
Aug 6, 2005 09:13 PM
