-   -   Clearing check engine light (https://nissanforum.com/forum/nissan-maxima-12/clearing-check-engine-light-366/)
Pod97654 Jul 28, 2005 12:36 PM
i was wondering? i have a 99 Maxima and i just a code (check engine light came on) I know that most of the older fuel injected cars could clear the computer by pulling the neg. bat. for about half and hour, does this still work or will have i to get the code cleared by my mechanic?
Pod97654 Jul 28, 2005 07:44 PM
RE: Clearing check engine light
I found out that disconecting the bat does not work. but for any one interested i found a free and easy way to check codes and clear codes on 95-99 maxima's.
Jedi007 Aug 1, 2005 04:54 PM
Go to O'Reily or AutoZone and borrow their ODBII Reader. You would probably need to give them your credit card as the collateral. Refer to the manual, obtain the trouble code and clear the "Service Engine Soon" light when you deem appropriate. I reset my 1997 Maxima several time at O'Reily. I hope it helps.
vrsexxin Aug 30, 2005 02:50 AM
well most of the times when you unplug the negative battery for resetting ecu, it works for minor ecu complications but if anything major like bad maf sensor, o2 sensor etc, it will not disappear by unplugging ecu....my best advice is go to schucks or autozone...but my 2 guess would be maf sensor or misfires..
Patrick Aug 30, 2005 03:18 PM
i would also suggest getting it scanned and find out why its on.
bonbon Sep 6, 2005 05:59 PM
I need some help, I have a 93 quest. my engine light came on , found the code 33, replaced o2 sensor, cleared code, and worked for few minutes, then came on again with same code, don't know what to do?
