-   -   Idle Air Control Valve 2001 Maxima GLE (https://nissanforum.com/forum/nissan-maxima-12/idle-air-control-valve-2001-maxima-gle-4515/)
mjand42 Dec 9, 2007 08:28 AM
Discussed recently this problem, also discovered this part is very expensive (OEM $280.00) & Auto Zone about $220.00, I did take apart the (idle air control valve) curious to see it function, also noticed past the throttle-body assemby( I guess it is called the air intake pleum, is heavy with residue build-up, I cleaned out what I could) put all parts back to same) also curious the in-out part of the idle air control valve has fluid present(anti-freeze???) is this normal, or I have additional problems to solve, inaddition to paying for new IACV, seems I made the problem worst at start-up(check engine lite is on & rev's are up/down on its own) car does run well after warm-up period, also this 3.0 Maxima is not to good on gas mileage, since I have owned it??? hopefully it is related to this Idle air control valve issue, down on my luck Thanks for any feedback to this issue
Burnnout Dec 10, 2007 01:01 PM
RE: Idle Air Control Valve 2001 Maxima GLE
You def. need to change that thing.... you will notice a huge difference in driveability. Pm me if you are interested in a better price for an OEM one.
