Maxima Engine Swap
Old Aug 25, 2006 | 02:47 PM
crackhouse20's Avatar
Default Maxima Engine Swap
I have a 3 month problem.I just swapped out a 2000 Maxima 3.0 engine to a 2003 Infinity 3.5 engine. replace time bilt with 3.0 and crank senser to 3.0.
The Problem
igntion coil 1 3 5
2 4 6
egntion coil "2" isn't sparking "4" is sparking correctly "6" spark...............stop..........spark.
The car sounds like it wants to turn over, but just needs that little push.
Please any answers!!!!!!!!!!!!!!!! I need help.........
Old Aug 26, 2006 | 09:30 AM
reiska's Avatar
Default RE: Maxima Engine Swap
ECU is/has the driver/s for coilpacks. Test/swap the problematic ones 2/6 with functional coilpack 4...
- if problem(s) are exactly the same, then the problem is in the driver and/or in the 2-4-6 -bank harness.
- If a problem is corrected with swap, the swapped coilpack is broken...
- Start by checking supply voltage at batt/ and ECU: +14V &gnd
Old Aug 29, 2006 | 10:23 AM
The coil packs are good. used same coil pack when testing for spark.Ecu is good used it on another maxima(all sparked)
Old Sep 30, 2006 | 04:26 AM
KA20DET's Avatar
nice swap
Zsmarts
Nissan 300zx
Jul 31, 2005 04:47 AM
Zsmarts
Nissan 300zx
Jul 27, 2005 10:39 AM
sasha
Nissan Skyline
Jul 27, 2005 08:31 AM
chubbz09
Jun 27, 2005 08:14 PM
Neological13
May 29, 2005 01:49 PM
