Need help w/ hose 95 MAXIMA
I need help identifying the hose shown on the picture. It’s a small (about 10mm) hose turning up near the valve cover, rear left (driver side) corner. I found the upper end of this hose disconnected. Engine seems to run OK with hose disconnected, but I need to know where it goes and connect it before I take the California smog test.
[IMG]local://upfiles/83/EC5613E2956C4CDF92E4314F3EA74A1D.jpg[/IMG] |
RE: Need help w/ hose 95 MAXIMA
are you sure it iZnt a crankcase breather hoZe?
do you see anything up top that it should be hooked up to? i would also think that it is a vent tube. with the car running, does the hose spray anything out at all, or create any suction??
hmmm, maybe he fixed it?
It was probably a vent. I passed the test.
Thank you guys. Tony |
good! glad everything worked out for you!
