oil leak
Alright so i had an oil leak on my maxima. Found out it was the front main seal (aka) secondary timing seal. Otherwise the neat little seal that sits behind the pulley. I got the part and replaced it now it leaks even worse then before. I talked to some people and they said that it might be because i didn't put in a speedy sleave. I was wondering if this would make a difference or if maybe there is something wrong with my pulley. Give me some ideas
RE: oil leak
The seal sits on engine, seals on cranck surface. Pulley doesnt touch.
You were given wrong seal or the seal was ripped/bent during installation. Been there... luckily happiness doesnt depend on what happens. |
