2000 pathfinder : How do I remove Front Rotor??
I would like to remove the Front Rotor on my
2000 pathfinder, to cut or replace it.
In the center of the hub, is a cap and several
small nuts around it. Which of these need to
be removed to take off the rotor?
Will I need to expose the wheel bearings to
remove the rotor, and if so what is the torque
value that I need to use when re-installing ?
Thanks for the help !
i beleive the front rotors will come off with out having to do that, remove the brake caliper and maybe a couple of screws holding the rotor onto the hub and it should come off.
michaeltroy
Apr 2, 2015 08:23 AM
