2000 pathfinder : How do I remove Front Rotor??
I would like to remove the Front Rotor on my
2000 pathfinder, to cut or replace it. In the center of the hub, is a cap and several small nuts around it. Which of these need to be removed to take off the rotor? Will I need to expose the wheel bearings to remove the rotor, and if so what is the torque value that I need to use when re-installing ? Thanks for the help ! |
RE: 2000 pathfinder : How do I remove Front Rotor??
i beleive the front rotors will come off with out having to do that, remove the brake caliper and maybe a couple of screws holding the rotor onto the hub and it should come off.
| All times are GMT -5. The time now is 08:42 AM. |
