2005 Climate Control Question HELP
Old 12-01-2005 | 11:45 AM
mjunda's Avatar
Default 2005 Climate Control Question HELP
I have noticed when I run my 05 pathfinder climate control on AUTO heat at approx. 71 degrees (really any temp) the air flow start with defrost and lower leg and then changes to lower leg. The air flow never changes to head/face even after a 10 mile commute. My feet feel great, but I was wondering if there is a issue with my climate control AUTO feature.
Keep in mind, I can always change in to MANUAL mode directing air to the head/face.
Thanks for your input.
Old 01-03-2006 | 04:20 AM
BigAlnyc's Avatar
Default RE: 2005 Climate Control Question HELP
No problem. The defrost kicks off after a short time and stays on the feet unless you manually change the location. Auto controls the temp not location. Just note that when you switch out of auto over to manual the new pathfinders turn on the air compressor (AC) for some reason, so you have to manualy turn them of. Guess the designers all live in Arizona Hope that helped
mwolf1
04-28-2011 01:11 AM
jdbryan10
03-14-2011 10:53 PM
gstric44
01-21-2011 11:01 AM
gstric44
12-12-2008 12:10 AM
razrielle
10-21-2008 09:35 PM
