2005 Pathfinder LE break Noise
Hi I am Ousmane new at this forum.
I got a 2005 Pathfinder LE with break squeezy noise when first driving foward or back up after the car has been parked for 2 or 3h and gets worse after rain or snow. I took it once back to the dealer but still having same problem. I just took it back a day ago and I am observing now. Usually it would stop for a few days and start again. Anyone having or had same issue and were they able to resolve it ? Thanks |
RE: 2005 Pathfinder LE break Noise
I have an 05 XE 4wd Pathfinder and my BRAKES are very quiet, no problems with SQUEEKING, just dust...
Hi,
I inquired to the dealer about the brake noise only in reverse cause I have the same annoying issue. They said because of the condensation the next morning and that the brakes are not fully broken in they will squeek in reverse. However.....I have noticed that when I reverse now they are not as noisey....the brake noise has dissipated..hope this helps. |
HELLO I HAVE 2006 PATHFINDER LE 4WD. AND I HAVE NO PROBLEMS WITH BRAKES. EVERYTHING IS THE WAY ITS SUPPOSED TO BE.
| All times are GMT -5. The time now is 05:21 AM. |
