2005 SE 4x4 Weird Clunk from the rear
I have a 2005 SE 4x4 that makes the wierdest noise ....similar to another post on here.
After you start the truck and go about 10-20 feet I hear a weird clunk in the back of the truck. It almost sounds like the noise when you run over a storm drain cover... It seems to coincide with shifting from first to second. It does it once then goes away until the next time I start the truck and go 10-20 feet with it. I would never notcie the noise with the radio on and the truck doesn't act funny when it does it. Has anyone else noticed this ? CC |
RE: 2005 SE 4x4 Weird Clunk from the rear
Hi, not sure if you have the UK model like mine, but all recent UK Navara pickups and Pathfinders with the same chassis are subject to a factory recall to have the prop shaft bolts checked. apparently some where not torqued up correctly at the factory .....
Update:
Hi all, I noticed when reading the owners manual (I know - if all else fails etc) and this seems to be covered by page 8-34. It says " The ESP (or VDC) computer has a built-in diagnostic feature that tests the system each time you start the engine and move back or forward. When the self-test occurs, you may hear a clunk noise and/or feel a pulsation through the brake pedal. This is normal and is not an indication of a malfunction". Hope that helps.....:) |
| All times are GMT -5. The time now is 04:04 AM. |
