94 pathfinder horn & cruise control
Old Jun 28, 2007 | 11:14 AM
mggsher's Avatar
Default 94 pathfinder horn & cruise control
The horn and cruise on my 94 pathfinder are working intermittingly. If I have the steering wheel/tires set to go straight both horn and cruise do not work. If I turn the wheel 90 to 180 degrees they work! I have removed the cover assembly, tried to check the wires (did not see any breaks); moved/jiggled wires to no avail. Both wire sets plug into the back of the steering wheel and appear to be on tight.Anyone have any ideas? Really frustrating.....
Old Jan 25, 2008 | 06:56 PM
mggsher's Avatar
Default RE: 94 pathfinder horn & cruise control
Turns out that the ground wire had a break in it at the connector. Screwed ground wire securely and horn & cruise now work.
Old Jun 7, 2008 | 06:24 PM
chdelamora's Avatar
Remove the steering wheel. You will see three copper 4 mm.diameter contacts pointing towards you. Those contacts complete the electrical connection for the horn and the cruise control. If they are too worn out, have an electrical technician solder copper of the same diameter on top of those contacts.
jmarks
Nissan 300zx
Sep 10, 2008 08:41 PM
kushyboy07
Oct 15, 2007 04:10 PM
txjohn65
Jun 1, 2007 09:47 AM
280zx
Feb 26, 2007 10:07 PM
rad3110
May 2, 2006 06:51 PM
