96 Patty EGR delete/bypass question
Old Nov 10, 2023 | 06:17 PM
rhensonsr's Avatar
Default 96 Patty EGR delete/bypass question
I just bought this PF and the EGR is broken where the pipe connects. I have tried to remove the pipe from the exhaust but cannot get it to break loose. Soaked it for 3 days with PB Blaster then put a 23mm crows foot on it and rounded the nut. Then I cut the pipe and inserted a 5/8 bolt into the pipe. Pulled the rubber hose and plugged it with a 1/4" bolt. I am going to put a 68k (68000) ohm 1/4 watt resistor into the electrical plug to kill the CEL. My question is do I need to plug the EGR port that goes to the exhaust or is it ok to leave it open? TIA
Old Nov 12, 2023 | 03:24 AM
Gazzer83's Avatar
Depending on where you live, it could affect your emmissions and fail an MOT. If you do go your route the best bet is to get a garage to check your emmissions. You could also try an EGR delete.
Old Nov 20, 2023 | 01:26 AM
rhensonsr's Avatar
Thanks for the input. I did not need to put the resistor in and the EGR opening has no leaks. Best of all there is no CEL.
dannc899812
May 25, 2008 10:50 PM
delmar
Apr 18, 2007 11:43 AM
gds154
Jan 10, 2007 03:46 AM
Jedi007
Aug 16, 2005 12:09 PM
Jedi007
Aug 1, 2005 06:04 PM
