-   -   96 Patty EGR delete/bypass question (https://nissanforum.com/forum/nissan-pathfinder-16/96-patty-egr-delete-bypass-question-41411/)
rhensonsr Nov 10, 2023 06:17 PM
I just bought this PF and the EGR is broken where the pipe connects. I have tried to remove the pipe from the exhaust but cannot get it to break loose. Soaked it for 3 days with PB Blaster then put a 23mm crows foot on it and rounded the nut. Then I cut the pipe and inserted a 5/8 bolt into the pipe. Pulled the rubber hose and plugged it with a 1/4" bolt. I am going to put a 68k (68000) ohm 1/4 watt resistor into the electrical plug to kill the CEL. My question is do I need to plug the EGR port that goes to the exhaust or is it ok to leave it open? TIA
Gazzer83 Nov 12, 2023 03:24 AM
Depending on where you live, it could affect your emmissions and fail an MOT. If you do go your route the best bet is to get a garage to check your emmissions. You could also try an EGR delete.
rhensonsr Nov 20, 2023 01:26 AM
Thanks for the input. I did not need to put the resistor in and the EGR opening has no leaks. Best of all there is no CEL.
