Changing wheel size
Old Oct 1, 2005 | 02:44 AM
salsarev's Avatar
Default Changing wheel size
My '96 Pathy has 15" factory rims. I'm thinking about changing them out to 16's, possibly some used OEM wheels. Are there any adverse affects as a result of going to a larger wheel size?
David
Old Oct 3, 2005 | 10:00 PM
Patrick's Avatar
Administrator
Default RE: Changing wheel size
well, you can alter the size of your tires in such a manner as to not actually change the diameter of your tires. if you pm me your complete tire size ( 2xx-xx-15) i can help you out with the proper 16 inch tires that wont throw your speedo out of whack.
or you can do it yourself..here is an example..
changing from 17s to 18s (my own car)
stock tire size. 215-50-17
215/25.4=8.46 inches wide.
8.46x.5=4.23 sidewall height.
multiply your sidewall height by 2=8.46
then add that number to the inner rim height, 8.46+17=25.46 overall tire diameter.
for the 18s, you want a tire that is as close to 25.46 as possible, as to not alter your speedo output...
if you wanted to keep the same tread width, your tire size would be 215-xx-18, and were solving for xx.
so, 25.46-18=7.46/2=3.73 sidewall height.
so since 215=8,46 inches
8.46x=3.73
x=.4409 since tire sizes only come in 5s...the tire size that would most closely match my factory size would be 215-45-18
keep in mind, that anytime you remove sidewall height, it makes the ride a little more rough...
Old Oct 4, 2005 | 12:01 AM
salsarev's Avatar
Thanks for the info. I'll give the formula a try.
David
Old Nov 10, 2005 | 11:19 PM
jerble's Avatar
How does the xtra mass, momentum if you will, of 16" 17" wheels over stock 15" effect Braking, ABS actuators/sensors thus response, throttle response? I am pretty sure that if you dont at least upgrade your brake pads to high quality ones or even upgrade rotor size; those 17s can cause some really noticeable brake fade. Ratio wont change since you used the right tires, true but there is more than just a speedo issue
Old Feb 26, 2006 | 11:20 PM
schnouse's Avatar
Check out http://www.finishlinewheels.com for Factory Origianl OEM Wheels and Replica Rims for you Pathfinder.
Tony82
Aug 15, 2007 11:19 AM
purple
Jan 9, 2007 10:39 AM
qutee72
Nissan 300zx
Jan 8, 2007 11:51 PM
celticbob
Audio/Visual Electronics
Jul 19, 2006 05:28 PM
wtroger
Feb 16, 2006 05:49 PM
