Front lights turned "dim"
Hiya,
I wonder whether anybody had similar problem with Nissan Pathfinder as I do. I drive model SE 4X4, from 2004, like the one in the pic 2004 Nissan Pathfinder SE 4X4 for sale from Huron - at www.cartrucktrader.com. Recently I've noticed that the lights turned dim, as if there was some fog under the front shield. I've read that you can use an ordinary drier to remove the moist from under the shield, but I don't want to make things even worse. Any advice? Thanks. Thanks. |
| All times are GMT -5. The time now is 07:32 AM. |
