Front seat moves only on left side
Old Nov 9, 2008 | 08:28 PM
StuartJ's Avatar
Default Front seat moves only on left side
I have a 2001 Pathy with a malfunctioning front driver seat. The forward/reverse seat movement is not working properly. The right rail drive functions, but the left rail drive does not, so when I try to move the seat forward, theright side of the seat moves forward a bit and then stops because theleft side is not moving. I pulled the seat out to look for the obvious, i.e. coin or golf tee blocking it. No blockages found either rail, i.e. they move freely when I disconnect the rails from their connections to the drive screws. This is where things are a bit more puzzling. I removed the electric motor. There is a spindle from the motor that drives the right screw drive, and this is working, so I know the motor is turning. However, the motor is not turning the left screw drive. Is this a connection problem within the left spindle housing? Can I replace this part without replacing the entire seat? Any suggestions are appreciated.
Old Jan 18, 2009 | 03:27 PM
chriscole9's Avatar
Default RE: Front seat moves only on left side
Did you find out what the problem was? I've got the exact same problem with my 2003 Maxima with the drivers seat.
xroad
Nissan Quest
Sep 6, 2008 12:54 PM
donzo27
Nov 12, 2006 08:50 PM
1998nissan2oosx
Nov 7, 2006 01:16 AM
MadMax
Oct 18, 2006 11:36 PM
HarborNissanFL
Mar 5, 2006 02:40 PM
