-   -   help with timing belt, 98 pathfinder!!! (https://nissanforum.com/forum/nissan-pathfinder-16/help-timing-belt-98-pathfinder-187/)
mannyfresh Jun 10, 2005 03:13 AM
Hello guys and gals,
Im new to the forums and in desperate need of help. Im doing a timing belt change on a 98 Nissan Pathfinder 3.3 v6 and ran in to a snag. I try to put the new timing belt on as per the Chilton, but it wont go. Seems like the belt is to tight. I can get it around the crank and the left cam but not around the right cam sprocket? And if I do get it around the both cams they move a tiny bit. I reset everything back to the notches. Any help will be greatly appreciated. Also the belt matches the old belt, so I dont think its the belt.
lentini Dec 18, 2005 07:45 PM
RE: help with timing belt, 98 pathfinder!!!
hey i see that post is a little old but i would like to know what ever happened in your endeavor
