Hoen replacement bulbs for the Pathfinder
Old Jan 6, 2006 | 12:14 AM
joe1115's Avatar
Default Hoen replacement bulbs for the Pathfinder
Has anyone replaced their factory bulbs using the Hoen bulbs?(both headlamp and fog lights) Did you have to get a new wiring harness or hardware? Did you have any problems with your headlamp assembly? (i.e. did it melt, or overheat b/c the higher wattage bulb?) Also, what model did you get?
Old Feb 27, 2006 | 06:27 PM
tonyg41's Avatar
Default RE: Hoen replacement bulbs for the Pathfinder
I replaced my factory bulbs with silverstar ones by sylvania for my headlights the only way your wiring would melt is if you go over the 65/55 9007 bulbs, If you go for anything higher or HIDS you need to get new wiring and theres also what looks like a transformer that comes with the HIDS. As for fog lamps im still trying to figure out how to install the kit i got for my 2006 PF but law is the wattage cant be higher then 55 watts for secondary lighting so you are limited there.
carid
Jul 7, 2022 01:42 PM
sabinat04
Mar 2, 2008 12:22 AM
m_man
Apr 16, 2007 12:56 AM
micknnev
Dec 2, 2006 05:43 PM
Bladen1
May 16, 2006 03:07 PM
