marker lights not working
hello, on my 95' pathfinder ebay jewel the marker lamps and dash lights don't work. all other lights work but those. does anyone know what the problem may be? thanks, noah
RE: marker lights not working
check your fuses first it sounds like you might of blown a fuse. check the fuse box thats by the drivers side kick panel and the one under the hood.
yea i checked the fuses and looked for broken wires. no power at any bulb sockets.? thanks though.
did you check the fuses with an ohm meter cause ive seen fuses that looked fine but where burned open, also if the fuses are good check for battery voltage at the fuse that supplies power to the marker lights and dash lights and make sure you have power there and also check your fuse box grounds. let me know if you have voltage and good grounds.
i replaced the headlight switch on my 90 and the dimmer switch and everything works fine
| All times are GMT -5. The time now is 05:01 AM. |
