My 1989 Pathfinder won't start
Old Apr 4, 2006 | 11:34 PM
srw45's Avatar
Default My 1989 Pathfinder won't start
My 89 v6 3.0 won't start, in just stoped and now it won't start. There are two codes in the computer # 1 is 11 and # 2 is 21 , did some of the checks with no luck appears to be no power to cpu at # 3 wire , where dose this power come from? really need some help, anybode? Steve
Old May 23, 2006 | 11:41 PM
Candy's Avatar
Default RE: My 1989 Pathfinder won't start
Did you ever find out why your Pathfinder wouldn't start. I'm having similar problems with my 91. We put in a new mass airflow meter, new plugs, new wires, checked the timing, fuel pressure and compression. Got worse over the course of 5 or 6 trips then just quit and won't start again. My mechanic is stumped. Can't even get it to run long enough to do diagnostics. Thought maybe you might know something I don't.
Old Feb 21, 2021 | 08:31 AM
Brandon Clark's Avatar
Default having the same issue mine is no spark
I was wondering if you found the issue I have a 91 with a 3.0 we are all lost
pathfinderrs
May 21, 2007 08:23 PM
mrspeedy69
Jan 30, 2007 10:40 AM
mrspeedy69
Jan 30, 2007 01:58 AM
srw45
Apr 21, 2006 10:58 PM
clroyer
Nissan 300zx
Dec 24, 2005 01:09 AM
