My 1989 Pathfinder won't start
My 89 v6 3.0 won't start, in just stoped and now it won't start. There are two codes in the computer # 1 is 11 and # 2 is 21 , did some of the checks with no luck appears to be no power to cpu at # 3 wire , where dose this power come from? really need some help, anybode? Steve
RE: My 1989 Pathfinder won't start
Did you ever find out why your Pathfinder wouldn't start. I'm having similar problems with my 91. We put in a new mass airflow meter, new plugs, new wires, checked the timing, fuel pressure and compression. Got worse over the course of 5 or 6 trips then just quit and won't start again. My mechanic is stumped. Can't even get it to run long enough to do diagnostics. Thought maybe you might know something I don't.
having the same issue mine is no spark
Originally Posted by Candy
(Post 5046)
| All times are GMT -5. The time now is 01:40 AM. |
