Nissan r51 2008 Pathfinder SE 4.0 Steering angle sensor issues
I replaced the steering angle sensor and cleared the codes. using a foxwell tool I can see that there is no data coming from the sensor. I have checked voltage with my multimeter battery shows 11.86 as does the power wire. Can anyone point me in the right direction Thanks, Jason |
You need to tell the car that it has been fitted. IE it needs to do a re-learn using a proper tool like an Autel etc.
| All times are GMT -5. The time now is 02:52 AM. |
