Noisy Engine
Old Nov 24, 2006 | 10:38 PM
Prestar's Avatar
Default Noisy Engine
Hi,..All. I recently bought a 1995 Pathfinder 3.0 V6, 82000 mi. Very good condition, Runs excellent. New Timing belt, waterpump, all new drive belts installed 11/2/06. Engine top end (it seems) is very noisy at start up when cold. Loud valve train. Rocker arms? There is also a high pitched metallic squeal/squeak in the mix. Sounds like all noise is sourced at the valve covers. Rocker/tapping noise quiets down substantially as engine is warmed,..but is always faintly there. The squeek/squeal disappears. I'm using 10/40 Valvoline Max Life. Any suggestions on an oil brand viscosity weight that is better suited to this engine? Or an oil additive I can use to help this problem? Are these symptoms common to this engine/year? Engine runs excellent otherwise. Thanks, Prestar
Old Nov 25, 2006 | 11:01 AM
Burnnout's Avatar
Default RE: Noisy Engine
5W30 Maxlife is more what you should be using.... adding a bottle of KREX goes a long way too.
Old Mar 28, 2008 | 11:22 PM
ExSniper4U's Avatar
try using motorkote
[align=left] [/align]
Old Apr 13, 2008 | 10:18 AM
pacificsun's Avatar
Sometimes people mistake exhaust manifold noise for valve train noise... check to see if one or more of the manifold bolts are broken...
Avalanche
Nov 30, 2006 11:03 AM
