pathfinder won"t start
Old Apr 4, 2006 | 11:26 PM
srw45's Avatar
Default pathfinder won"t start
It just stop running and will not start. It cranks over but no fire. Codes are #1 11 and # 2 is 21. This is a 1989 3.0 v6 need some help on this one,Steve
Old Apr 21, 2006 | 10:58 PM
Default RE: pathfinder won"t start
well there alot to check. check to see if you have fuel psi cause maybe your fuel filter is clogged, or timing belt/chain is busted there are too many to list for a no crank problem. all an engine need to run is fuel, air, unclogged exhaust,valve timing, and spark. if your not sure what to do take it to your mechanic and have them check it your going to have to pay for about one hour of diag. to find the problem then parts and labor to fix it.
srw45
Feb 21, 2021 08:31 AM
pathfinderrs
Jul 15, 2007 10:36 PM
pathfinderrs
May 21, 2007 08:23 PM
mrspeedy69
Jan 30, 2007 01:58 AM
srw45
May 15, 2006 12:43 PM
