`94 Quest starting problems
Won't start. Starter motor is good. Battery is good.
Not getting proper signal to start relay. Inhibitor switch tests good according to the Nissan manual. If I jumper out the inhibitor relay, it will start but it won't keep running. Anyone familiar with this problem ? Thanks. |
RE: `94 Quest starting problems
I found the problem. It was a bad wire (or connector terminal under the dash) between the fuse block and the inhibitor switch connector.
| All times are GMT -5. The time now is 12:11 AM. |
