-   -   04 Quest SE, P0705 DTC Help (https://nissanforum.com/forum/nissan-quest-30/04-quest-se-p0705-dtc-help-17005/)
MotherOfTheYear May 9, 2018 09:29 PM
My 04 Quest SE is showing a P0705 DTC "Transmission Range Sensor A Circuit (PRNDL Input)". I have been searching for info specifically related to Quests or Nissans in general and have come up empty. Does anyone have any experience with solving this code on Nissans? Any good trouble shooting guide? My AT fluid level is good. I plan on ordering the (PRNDL) switch and starting with that, but I need to know if my van has 5 or 4 gears because they have different part #'s. Does anyone know a easy way to tell how many gears my AT has? Appreciate any helpful feedback, thanks!
MotherOfTheYear May 10, 2018 09:12 PM
I found the Transmission type on the sticker on the drivers side b pillar. RE5F22A, which is the 5 gear, so that's solved. I read somewhere that all Quest SE models have the 5 gear. Does anyone know where the "TRS" is located on these? Is it outside the transmission housing or does it link to the shifter under the dash?
