Front Right Rotor
I am trying to take off my front brake rotors, and my left (driver side) rotor comes off fine, however my right side appears to be stuck or secured on there somehow. I completely removed the brake caliper, and even tapped it a few times with a hammer, and still no luck. Any help would be welcome. Thanx. TH
RE: Front Right Rotor
What year is the Quest? Is there any rust near the rotor? My dad has a 2000 and I changed the rotors a few months ago. His driver's side rotor was a pain in the butt to get off, but I got a flat-head screwdriver and some brake cleaner and pryed it off. It was rusted on, so you can try prying it off, but make sure that you do not damage anything else when you do it. Are you changing them b/c they are warped? Good luck. (My intials are TH too:D)
I just remembered that there were bolts on the back of the rotor that you have to screw in to get it off. Once again, its a 2000 Quest, so it might be different. Hope that helps you out.
| All times are GMT -5. The time now is 02:08 AM. |
