-   Nissan Rogue (https://nissanforum.com/forum/nissan-rogue-43/)
-   -   Rogue windshield washer sytem (https://nissanforum.com/forum/nissan-rogue-43/rogue-windshield-washer-sytem-17513/)
brunder Nov 30, 2021 04:38 PM
Has anyone noticed an extremely weak stream coming from the windshield washer system in the 21 rogue? Its so weak it barely gets to the windshield. ANy way to change this? DIfferent wiper blades?
irontmp Nov 18, 2025 11:22 PM
Originally Posted by brunder (Post 30129)
Has anyone noticed an extremely weak stream coming from the windshield washer system in the 21 Rogue? I’m wondering if I should book mobile auto glass repair to check for any nozzle or hose issues. It’s so weak it barely gets to the windshield. Any way to change this? Different wiper blades?
The weak stream on the 2021 Rogue is usually caused by the “Splash Free” wiper design, clogged or misaligned nozzles, or a weak pump or hose. It’s not related to the wiper blades, so changing them won’t improve the spray. You can try gently cleaning the nozzles, checking the hoses for kinks or leaks, and making sure the washer fluid is full. If the problem persists, replacing the pump or the nozzles can help increase pressure. Some owners also use aftermarket or hood-mounted nozzles to get a stronger, more consistent spray.
