-   -   2010 Nissan Sentra TPMS (https://nissanforum.com/forum/nissan-sentra-20/2010-nissan-sentra-tpms-17411/)
FelimStewart Jun 17, 2021 01:51 AM
Hey, what is going on, guys? Today I’m going to show how programming tire sensors on 2010 Nissan Sentra Autel MX-Sensor, using thethis is newest Autel tire sensor to use, it applies for either US models or European Models, because it has 315MHz (for US model) and 433MHz frequency ( for the other side of the world). The newest Autel MX-Sensor has the ability to be programmed on both frequencies.
https://cimg8.ibsrv.net/gimg/nissanf...7a89b41599.jpg
To program these sensors, you’re gonna need a tool like this: Autel MaxiTPMS TS508.
This car has a sensor bad so I already changed it. This sensor comes in blank, put it in the slot to scan it: Quick mode >> Nissan >> Sentra >> 09/2006-05/2016(315 MHz)(B16)
https://cimg9.ibsrv.net/gimg/nissanf...9b4a317487.jpg
Program sensor >> Auto create 1-16 sensors, it tells the sensor must be outside of tire.
https://cimg0.ibsrv.net/gimg/nissanf...d8b03549aa.jpg
https://cimg1.ibsrv.net/gimg/nissanf...2f1d9d32fe.jpg
https://cimg3.ibsrv.net/gimg/nissanf...2c2008c0bd.jpg
The sensor detected, Continue >> Programming >> An ID was created, “OK”
https://cimg4.ibsrv.net/gimg/nissanf...6f13d4f715.jpg
https://cimg5.ibsrv.net/gimg/nissanf...6e81b4fbbb.jpg
Exit to scan the sensor: N button >> Scan All Sensors, done!
https://cimg6.ibsrv.net/gimg/nissanf...4e0322200a.jpg
https://cimg7.ibsrv.net/gimg/nissanf...652ae434b8.jpg
https://cimg8.ibsrv.net/gimg/nissanf...121810fa73.jpg
Once the sensor is programmed, you should put it in the tire. Then read its ID via Autel MaxiSys Elite:
Diagnosis >> Control Unit >> BCM >> Air Pressure Monitor >> Live Data
As you seen, the ID here and tire pressures, but they are not activated.
https://cimg9.ibsrv.net/gimg/nissanf...45ddc708fc.jpg
So return to Special functions >> ID read >> Check if the ID was matched each tire, if not, assign to CORRECT tire.
https://cimg0.ibsrv.net/gimg/nissanf...d1e4b1d819.jpg
https://cimg4.ibsrv.net/gimg/nissanf...4ab77fb447.jpg
Return back to ID Regist >> OK >> Start
https://cimg5.ibsrv.net/gimg/nissanf...e4aa403291.jpg
https://cimg9.ibsrv.net/gimg/nissanf...db971836e8.jpg
https://cimg1.ibsrv.net/gimg/nissanf...cdd0e8ec09.jpg
https://cimg4.ibsrv.net/gimg/nissanf...ee9d0556f1.jpg
Now I am going to activate each one with AutelTS508 tool, put it near the sensor, scan it after hearing beep.
https://cimg8.ibsrv.net/gimg/nissanf...e8ab8c01ef.jpg
The screen tells “Done”, follow same operation for other tires until all “Done”.
https://cimg1.ibsrv.net/gimg/nissanf...b5c263b7ad.jpg
Now let me check all the lights, there is no more warning lights, successful!
Autel MX-Sensorhas the ability to be programmed on different frequencies, it is really cheap and last for a long time I will recommend.
https://www.auteldiag.com/
