Cant take of a 4wheel drive trans HELP!!!!!
i have a sr20det motor and im trying to take the 4 wheel drivie transmission
I need Help ASAP.Call me please 5614527981 |
RE: Cant take of a 4wheel drive trans HELP!!!!!
use some pentrating lube and let them soak for a little bit and then use an impact on them cause if you use a ratchet or a wrenck you will take a chance of breaking the bolt. good luck
