CV Joint replacement
Old Jun 14, 2007 | 10:09 PM
f22c130's Avatar
Default CV Joint replacement
Has anybody ever had to replace the CV joints in their sentra?I've gotta repair manual and it doesn't seem extremely difficult, but I would like to hear from somebody whose done it before and knows from experience. Thanks
Old Jun 19, 2007 | 12:29 PM
rallysentrajoe's Avatar
Default RE: CV Joint replacement
what year sentra is it? I have an 89 and its realy easy to do it tokk me like 10 min to do it.
Old Jun 19, 2007 | 12:37 PM
if you have a b13 or b14 sentra that not hard, your going have to jack up the car and put on stands (the higher the better) and your going to need a 1"1/4 or 32mm deep socket to remove the axle nut and then your going to need to pull the cotter pin out of the lower ball joint and use an open end wrench 22mm or 24mm not sure and your going to have to loosen and and break the ball joint loose with a pry bar, to pull the ball joint nut off and then put the axle nut slightly on the axle and hammer it out of the hub so you dont mushroom the threads on the axle then you use a pry bar and put it between the tranny and inner cv on the axle and pry it out, your going to need a drain pan cause its going to drain tranny fluid and then replace the axle and repeat the procedure in the reverse order and add tranny fluid and your back on the road. the hardest parts can be breaking loose the ball joint axle out of hub and possibly getting axle out of tranny if its an older sentra.
Old Jun 19, 2007 | 01:34 PM
f22c130's Avatar
It's a '98 with the 1.6L engine.
Old Jun 19, 2007 | 01:36 PM
then its exactly the way ive explained it good luck on the repair.
nomad
Aug 8, 2007 04:10 PM
alkon
Mar 13, 2007 08:14 PM
craig01kc
Oct 16, 2006 07:58 PM
mastermech911
Nov 15, 2005 07:39 PM
wicofleland
Jul 28, 2005 07:52 PM
