det swap
i have a 96 g20 with a bluebird swap. it will turn over but won't start. the fuel rail gets fuel and it gets spark but the injectors won't work suggesting ecu problems. i'm running the stock de ecu which i've heard will work as long as it's tuned which i have an afc but it does no good if i can't start it. if anyone has any suggestions it would be appreciated. thanks.
RE: det swap
check forgrond and false contact on ecu
RE: det swap
You need the ecu or a reflash from jim wolfe.... I'm told.
