Door Panel
How can I take my door panel off my 98 Sentra if my door wont open?
RE: Door Panel
take the seat out
RE: Door Panel
but the seat isnt in the way
RE: Door Panel
can you not get to the bolts because the way it sits when the door's shut?
RE: Door Panel
yeah
RE: Door Panel
gonna have to figure out a way to get that door opened otherwise i dont believe itll be possible. whats the reason the door wont open?
RE: Door Panel
your going to have to use a slim jim or somthing to pop open the door is the inner door handle broken or is the latch assyembly broken if its just the door handle remove that screw and take the handle out and pull the rod the handle pulls.
RE: Door Panel
yeah, no other way to get the door panel off without having the door opened up
RE: Door Panel
ORIGINAL: HXC_Nismo your going to have to use a slim jim or somthing to pop open the door is the inner door handle broken or is the latch assyembly broken if its just the door handle remove that screw and take the handle out and pull the rod the handle pulls. |
