| HXC_Nismo |
Apr 27, 2006 11:55 PM |
RE: electrical problems
it sounds like your brake switch is stuck closed, its by the top part of your brake pedal under the dash, and there easy to put in just make sure you adjust it to turn the brake lights on when you barely move your brake pedal. you can get the switch from any nissan dealer and if you dont feel comfortable to put it in since the diagnosis has already been done you would only be looking at about half an hour of labor wich is about $40 to install plus part. well let us know how it turns out. good luck
