Emergency brake light on-but not the brake
Hi. Yesterday I noticed that the emergency (hand) brake light stays on when the brake is off. The car doesn't act like the brake is on at all. No noticable braking action at all when letting up on the gas or putting on the clutch.
94 Sentra XE Any ideas? Thanks. |
RE: Emergency brake light on-but not the brake
could be slack in the line (i know that happened in mine) or just a problem with the sensor
I wondered about slack. But how do I check the sensor?
check your master cylinder and make sure the brake fluid isnt low cause that can also cause the brakelight to come on.
Nissan Clutch Master Cylinders
check out the sensors your nissan clutch cylinders brake light it could have low in brake fluid. |
the brake fluid seems to have solved the problem! Thanks all for your suggestions. I'm glad it was such an easy fix!
no problem always check the most obvious
| All times are GMT -5. The time now is 01:06 AM. |
